trigger loop with an external waveform
Hi All,
My problem is the following: I need to add up consecutive readouts (waveforms) form an instrument (Tektronics, TDS7154B) untill some treshold is reached. I have already configured the instrument, so I can capture readouts via GPIB. Now, each readout is triggered externally by other channel of the same oscilloscope. Is there any structure (or some sequence of structures ) that could be triggered externally by the scope, so that it executes only when triggering event occurs?
Best,
Lukasz
(3,084 Views)
I think you can set up the timing source for a timed loop to run from an external trigger.
You can then use a DAQmx device counter input as the timing source.
Have a look at the "Event Response.vi" in the examples.
(C:\Program Files\National Instruments\LabVIEW 8.5\examples\DAQmx\Control\Event Response.llb\Event Response.vi)
http://digital.ni.com/public.nsf/allkb/1A2AC87AAABCB70986257164000146FD
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(3,072 Views)
