triggering with Keithley 6221 and measuring the voltage via 2182A without the delta mode
hello
I am trying to trigger my devices with current pulses through keithley 6221 and want to measure the voltage across them via keithley 2182A. As far as I understand, it is not possible to do it in the delta mode so I wanted to modify the wave generator example vi of 6221 and add the 2182A  instrument in that to measure the voltage with timestamp. Could anyone suggest me a way to how to go about it. I would be grateful. Thank you.
Message 1 of 1
(2,535 Views)
