tristate color indicator with pda module
I want to make a tristate color indicator (3 color led in fact) for an application running on pocket pc.
I can't use property nodes nor colorboxes due to the restrictions of the pda module.
 I'm working with labview pda 7.0.
Thanks.
Message Edité par maveman le 10-18-2005 07:45 AM
Message Edité par maveman le 10-18-2005 07:46 AM
(3,413 Views)
Use a picture ring or a picture control where you draw a rectangle of the proper color.
___________________
Try to take over the world!
(3,392 Views)
This features are not available with PDA module...
(3,371 Views)
"Use a picture ring... "
Nice guess tst!
I thought the same thing but did not have the guts to expose my ignorace re:PDA.
Ben
(3,368 Views)
OK, I don't think I have 7.0 PDA installed any more and I don't have access to 7.1 PDA at the moment, but I looked at the user manual for 7.0, which doesn't mention that there is no picture control support and I seem to remember that the picture control was supported in 7.0 and I know for a fact that it is available with 7.1, so I suggest you check again to see if the picture control (not picture ring) is supported. If it is, you can use my second suggestion (drawing rectangles).
___________________
(3,363 Views)
You're right ! Picture control is supported in LabView PDA module 7.0.
Now, I can make my tristate led...
Thanks a lot for your help.
(3,345 Views)
