trouble appending to excel file
Hi, I'm using a case structure to write excel files based on the example http://digital.ni.com/public.nsf/allkb/EFCE1C25DCE7483E86256CAF00539451. It is writing new files beautifully, but it is NOT appending to existing files. Does this have anything to do with the for loop? Is a for loop required to append data? If not, are there any other suggestions?
Andrea
(2,273 Views)
Post your VI so we can see how you are doing it.
(2,270 Views)
Hey Andrea,
Please post code so we can compare the difference between example and yours.
Ricky
(2,253 Views)
