trouble installing gxml library for LV2011
When I run the setup file, I just get a msg indicating no files will be installed or removed.  Any ideas?  thx...
(3,006 Views)
Accepted by topic author atlasHW
assuming if you have more than one version of LV on the same PC, setup file does feel the need to reinstall the library...
is there a better way to address this than just copying the folder from one user library folder to another?
(3,002 Views)
Hello atlasHW,
Where are you trying to install GXML from? Is it the gxml_140_installer.zip file found here: http://zone.ni.com/devzone/cda/epd/p/id/6330#0requirements? A screenshot of the message you're getting would be really helpful as well.
Carisa Leal
Applications Engineering
(2,986 Views)
Problem resolved - I had to copy the files from my 2010 user lib to 2011 and mass compile (new to me, I'm just a beginner).  Thanks for the follow up.
(2,982 Views)
Glad to hear everything is up and running!
(2,978 Views)
