trouble installing-internal error 2359
I am an engineering student and I am having trouble installing LabVIEW in my personal laptop. I keep getting the message box that says "internal error 2359"
(3,056 Views)
Sarah,
Here is an excellent online document that talks about internal error 2359 during the installation
KnowledgeBase 20OD9LQC
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/0663d5f7bb486375862569460069f47c?OpenDocument
It is basically a Microsoft Installer Installer, that we use for installing LabVIEW, error on WinNT based operating systems. You will need to change some permissions configuration, and the above documents explains how to do it in details.
Zvezdana S.
(3,056 Views)
I cannot open that web address that you gave me. I dont know if it is a problem with my computer or maybe there is an error in the address. Thank you and I appreciate your help.
(3,056 Views)
Sarah,
I double checked the address, and it is the correct one.
If the link does not work, try copying the URL into your web browser.
You can also try searching the ni.com for this document ID: 20OD9LQC. It is a KnowledgeBase, so you can search first the KnowledgeBase web page.
Zvezdana S.
(3,056 Views)
