trying to send mail
I am trying to figure out why my mail agent will not work I get an error and for what ever reason it does not make sense to me I hope sombody can help me.
here is a picture of both my FP and BD
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,067 Views)
ok so I changed it to the send message but I am still getting an error
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(4,040 Views)
Why don't you search the board for 'gmail'? It requires authentication and the built in LabVIEW functions do not provide that. There have been posts that show how to use .NET and OpenG functions.
(4,025 Views)
Sending mails though Gmail using .net functions.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(4,022 Views)
Yeah I found that example I just figured there may have been a better way.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(4,014 Views)
The reason you cannot simply use the SMTP email functions is because of Authenitcation.
I noticed the email you are trying to use has a .edu extention.
This means the email server probably uses SSL or TLS security, so you would need a little more code to handle that. Here is a thread that discusses this.
Cory K
(3,977 Views)
Also, do not use TLS (or SSL) security as a default.
This works fine if the email server uses this security, but otherwise will throw an error.
For example, if you use this VI to email someone with an AOL, Yahoo, email, there is no TLS security,
so it will be confused if you try to provide credentials.
Its kind of like handing in a typed CV when applying for McDondalds.
(That was probably an uncalled for analogy.... bad Cory)
Cory K
(3,943 Views)
