trying to use the TIMER to work out how many mS there are between triggers
I observe that the previous time indicator subVI on the front panel shows values in hundreds or thousands. I could not understand why, although the time indicator subVI on the frontal panel is fine and in seconds or mS.  Could you please guide me...
Kind regards
Hasham
Message 11 of 23
(875 Views)
Not sure what is going on. Try the following.
Message 12 of 23
(865 Views)
The current an previous times are relative, only the difference is meaningful. I am not sure where you get mS (millisiemens). That's not a time unit.
If you have problems with code, attach the code!
Message 13 of 23
(859 Views)
First of all sorry for late reply and same time thanks for your reply. As this code is working and now I want read run time of code without FOR/WHILE loop.
Kindly please guide me.
As I attached LV19 version code.
Kind regards
Hasham
Message 14 of 23
(809 Views)
First of all sorry for disturbing you all. I want to read the run time of the code without the FOR/WHILE loop.
I have attached the LV19 version code.
Kind regards
Message 15 of 23
(810 Views)
Hi Hasham,
Even though you claim to have attached a LV2019 VI (and also named the file as such) you failed in doing so: your VI is in LV2022…
Please don't create duplicate posts in different threads for the very same question.
Generic answer as I cannot open your code:
Get the timestamp at start of your VI and before finishing, subtract both timestamps. THINK DATAFLOW to define the execution order!
Message 16 of 23
(797 Views)
Kind regards
I cant see your code so I am answering with some arbitrary code : )
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 17 of 23
(772 Views)
Sorry for the late reply. I tried to use timestamps in the code, but I could not get any values... I attached an old version of the code, and if you don't mind, please guide me...
Kind regards
Hasham
Message 18 of 23
(746 Views)
Sorry for the late reply. I have attached the LV19 version of the code.
Kind regards
Hasham
Message 19 of 23
(745 Views)
Sorry for the late reply. I tried this example but did not get values.
I attached my code LV19 version.
Kind regards
Hasham
Message 20 of 23
(742 Views)
