tuning external component toa particular voltage level with labview
i need to check the voltage levels of two components(for ex: speaker o/p) in the unit under test using labview .And, if the levels are not to the desired level, I need to tune a couple of other components(for ex:volume controls) on the board so that the level of the speakers comes to desired level.This tuning is not to be done manually. It should be programmed!
(2,529 Views)
Are you using a data acquisition card? If so, the job is very simple, You can sample the output level with an analog scan vi, and use it in a feedback loop. This can control an audio frequency analog output (if you have a multifunction DAQ card)
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,529 Views)
