turntable with LabView control
Does anybody know a cost effective turntable with LabView control/drivers ? 5 or 10 kg load and 20 to 40 cm diameter would be ok.
(3,273 Views)
Doesn't that need some more requirements?
Like position uncertainty or angular speed or angular acceleration, hold force??  (just the ones that came to my mind)
Some of the turn tables (you know these things to play music from vinyl LPs 😉 ) migth be able to hold 5kg, add a LabVIEW controled switch and your done 😄
It's Fridays isn't it?
Greetings from Germany
Henrik
LV since v3.1
(3,244 Views)
Oups sorry...
- positioning from 0° to 360° or -180° to +180°
- postioning accuracy 1°
- rotating speed 2 rpm
would be fine. I need it for micro antenna directivity measurements (weight of the antennas 100 gr to 1kg).
(3,234 Views)
Outdoor? (Wind load?)
Henrik
LV since v3.1
(3,217 Views)
