two analog input tasks
I have a VI with two analog input tasks. One outputs a waveform, from which I determine the frequency of that waveform. Another one just samples the signal once, because all I need is to one value from the signal.
Is there any way to synchronize these tasks? Right now I perform one task then the other because from what I know, you cannot perform two analog input tasks at the same time.
I've attached a VI. Thanks for the help.
(3,502 Views)
duplicate post. Try to to keep the same question in one thread. What is wrong with adding all of you channels to the single task as recomended?
(3,499 Views)
wow I am very sorry. I did not notice that my last question got a response, so I re-posted it.
Apologies. I will try what Chris K recommended.
(3,496 Views)
