two counters simultaneously 6023e
hello
Is possible use two  conters simultaneosly in board 6023e.
Message 1 of 20
(5,525 Views)
Bonjour,
Yes it is.
Johan G.
NIF
Message 2 of 20
(5,495 Views)
But how? Can i put two conters work in parallel accioned by the same trigger signal.
Message 3 of 20
(5,489 Views)
Can you be more specific.
What do you want to do?
What software do you use? What version?
I speak french, so if you prefer you can explain me what you want to do in French.
Johan G.
NIF
Message 4 of 20
(5,477 Views)
I'm not sure about what you mean by "two conters work in parallel accioned by the same trigger signal" if you are using DAQmx (I don't know anything about DAQtrad Smiley Indifferent...) it is of course possible to have 2 counters working at the same time.
Please discribe more accuratly what you need and also you can check DAQmx example VIs Help >> Find examples... >>
Hardware Input and Output >> DAQmx 😉
Message Edité par TiTou le 03-10-2006 10:01 AM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 5 of 20
(5,476 Views)
wnhen i try start two counters dev1/ctr0 and dev1/ctr1 the labview give me this message.
ERROR 50103 OCCURRE AT DAQMX START TASK
THE SPECIFIED RESOURCE IS RESERVED. THE OPERATION COULD NO BE COMPLETED AS SPECIFIED
Message 6 of 20
(5,465 Views)
Could you post your code please ?
Epictetus
Antoine Chalons
Message 7 of 20
(5,456 Views)
i would like make the output off one counter (counter0)be the gate off another counter (counter1) but for this i need start the two counters simultaneously and then the labview give me the error 50103
Message 8 of 20
(5,455 Views)
There is a simple example two counters one counter is a clock for another one.
This example dont work i don´t know why.
ftp://ftp.ua.pt/incoming/tc/two%20counters.JPG
Message 9 of 20
(5,419 Views)
I have had 8 counters running in parallel using a 6602 , essentially you use buffered counting on each channel with a shared trigger/gate and each uses their own source.  The gate signal can be external or intrinsically generated from the card.  Be aware that if you make a pulse train from the board you end up using up one of the counters and then can not have two channels anymore.  Post some more details on the counter/timer message board.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 10 of 20
(5,408 Views)
