two diferent devices under the same VISA resource
Is the fist time I work with VISA, and I have a simple question... if I want to control two different devices, should I have two different VISA resources? Each VISA resorce would be related to each device (a given port) Is it ok? I have seen one example to control two devices, but there is only one VISA resource, so I am confused...
Thanks in advance!
(2,691 Views)
Yes, each resource would be unique. If you are going to mention an example, you need to provide a link.
(2,681 Views)
I attach the  example I was talking before. In this example,  it is sent the same request for two devices (Ej linear stages) at the same time. I would like to control two stages at the same time but with different requests. Therefore, should I have two VISA resources?
My two devices are connected by means of RS-232 to USB converters, therefore, which VISA resource name should I use?
Thanks in advance for your help,
(2,658 Views)
That example is talking to a device with a single serial port connection and internally it uses a device number to differentiate. If you have two separate serial ports connected to two different instruments, then you must have two separate VISA resources.
(2,655 Views)
