two exe in parrallel
Dear Sir,
i am using labview8.2. I created two exe of same source code for two different application one for forward and other for reverse. I am able to run these both exe in parallel and they are working ok. Now i want in such way that when i click rev button from forward exe front pannel it will show reverse exe front pannel and minimize forward exe front pannel. Similarly when i click fwd button from reverse exe front pannel it will show forward exe front pannel and minimize reverse exe front pannel
Regards
Manasi
(2,845 Views)
Why don't you simply built a new application that does both in one program?
(2,839 Views)
both applications are having large source code so i cannot redeveloped it
(2,835 Views)
You can solve that through network published shared variable, it sounds like band aid, but whould work.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,818 Views)
