two instances of same app
I have a LabView exe file that is used to control one of our devices on a com port.
We use an FTDI device that makes a USB port appear as a com port.  There are no problems with this.
Our devices output data approximately every ten seconds and I keep the com port open and check for data approximately once per second.
The PC that runs the app has four USB ports, each connected to one of our devices.
I thought that I could open four instances of the app, one for each port.
However, I could not get multiple instances of the app to execute.
After searching what few old threads I could find related to this (2005 and earlier), it appears that I cannot open multiple instances.
There are also comments that multiple VISA resources cannot be open simultaneously.
So now my questions...
Can I have multiple VISA resources open simultaneously (say one for COM4 and one for COM5)?
Can I open multiple instances of an app?
Can I open different apps that use different VISA resources at the same time?
All help is appreciated.
(2,956 Views)
Yes you can!
Either rename to the level VI for each instance or use a template which will acheive the same effect.
Make sure all of the sub-VI-s are re-entrant.
Ben
(2,941 Views)
For an exe, a search turned up this thread for the same question. You have always had the ability to have multiple VISA resources open.
(2,937 Views)
Thanks Ben and Dennis.
Dennis, your solution is exactly what I had hoped for.
Don't know why i didn't find that thread with my search.
(2,898 Views)
