two mutual exclusive condition
Hello:
I have two valves(or you can regard them as two controls) that can not be open at the same time. If they are open(true) at the same time, a error message will be popped up.
I programmed a very simple Subvi and the final value will be used to change the local variable of the operating valve(the control whose valve will be changed). But, when I put this Subvis into my main programm, it does not work because it will close both of the valve at the same time.
The reason I have operating valve and confilicting valves is that I have to check the other valve status whenever I open one of them.
Can anyone help me for the attached programm?
Thanks a million,
Message 1 of 9
(3,461 Views)
Hi Connector,
Speaking only for myself I have to say that I am not sure what you need. At first I thought you where looking for an exclusive OR operation, but after looking at your VI, I am confused.
If you provided a truth table most all of the "frequent Flyers" here could probably fire off an answer.
Trying to help,
Ben
Message 2 of 9
(3,461 Views)
Hi, Ben:
Here are the truth table:
Operating Valve Conflicting Valve HS Final status
t t t t
t t f f
t f t t
t f f t
f t t f
f t f f
f f t f
f f f f
Thanks a lot
Message 3 of 9
(3,461 Views)
A quick Venn diagram, some boolean arithetic...
See attached,
Ben
Message 4 of 9
(3,460 Views)
Hello Ben:
Thanks for your help. I figure out to use this also, but How can I pop up a message to tell the operator that this operation is not valid?
have a nice day
Message 5 of 9
(3,460 Views)
Use an AND gate to drive a case structure with you one-button dialog.
Ben
Message 6 of 9
(3,460 Views)
Thanks.
I tried your program. It still does not work perfectly. If a is true, when I turn on b, I can not turn on it, that's right. But, I should not turn off a at the same time.
I change a little on your code. Can you take a look at it?
Message 7 of 9
(3,460 Views)
So,
If [(A&B) is false ]&[C is true] then
Ain = Aout
Bin = Bout
See attached
Ben
Message 8 of 9
(3,460 Views)
I really appreicate your help. Here is the code again. Actually, the output of this Subvi will be the local variables to reset the valve status.
Message 9 of 9
(3,460 Views)
