08-14-2009 08:21 AM
Hi guys
I am trying to acquire voltage using NI 9205 in a cDAQ chassis. I want to acquire two different signals at the same time so that i can subtract one voltage from the other.
Just a jist of my application: basically i want to perform V1 - V2. I know that the first impression would be using a differential mode. But both my signals are acquired in differential mode. if it helps, one signal is random and the other signal is dc (from a thermocouple). and i have to obtain the random signal from the channel (thats the restriction).
when i tried it using two physical channels in my program i was getting an error.
any suggestions?
Ishan
08-14-2009 08:38 AM
If your DAQ task is setup right, you should get a 2D array of data.
Rows, #chaneels read
Cols, #data points read
So by subtraction of row 1 from row 2 your problem should be solved ![]()
Anyway, what error do you get?
Can you share some code?
08-14-2009 11:56 PM
hi alain
the attachment contains the vi which i tried out. the error which i encounter is Error -50103 Possible reason(s):The specified resource is reserved. The operation could not be completed as specified.Task Name: _unnamedTask<2> .
i am sending you a screenshot of the error display.
going back to your suggestion: yes perhaps looks the more logical way of doing the task. i will try it out. ( i am a newbie so i will take some time)
thanks
cheers
ishan
08-15-2009 01:45 AM
To specify a range of physical channels, use a colon between two channel numbers or two physical channel names:
Dev0/ai0:4
Dev0/ai0:Dev0/ai4
For digital I/O, you can specify a range of ports with a colon between two port numbers:
Dev0/port0:1
You also can specify a range of lines:
Dev0/port0/line0:4
Dev0/line0:31
You can specify channel ranges in reverse order:
Dev0/ai4:0
Dev0/ai4:Dev0/ai0
Dev0/port1/line3:0
Use commas to separate physical channel names and ranges in a list as follows:
Dev0/ai0, Dev0/ai3:6
Dev0/port0, Dev0/port1/line0:2
The loop of a solution with only one DAQmx "string" will look like this
Good luck!
