Hi all, I need to write two string values and a number value to file. I made a basic VI showing what is needed. I figured to cheat a little by sending my time stamp to the comment node. I then converted the id string to a decimal number and merged it to my numeric value. All is great with the output in Excel, accept my ID string dropped the last two digits and replaced them with a zero. Even if I used a numeric constant with this same value, it replaces the last to with zero's. The problem seems to reside with the write to measurement file VI. If I open it directly with wordpad it saves it as 2.602189E+8. Any ideas to save these three values? Thanks
Gerald
