two-way math
This may be a silly question...but is it possible to wire two controls so that they affect the other?
Specifically:
I have control A and B and want them to sum to 10. Changing control A will affect the display of B in real time, and vice versa.
(3,559 Views)
Accepted by topic author stwlee
Use an event structure to key in on the value change of A.  In it, you do the math and update B with a local variable.  Do the same thing with the value change of B to update A.
(3,543 Views)
Thanks. I had to fiddle a bit with the location of the inputs and whatnot, but it seems to work without issue!
(3,523 Views)
