txt file to scale
@WM09 wrote:
Thanks!
i did as you told me, but it doesn't return the number i need, for example, y tried with -117.3907001, and it should have return the number next
to it (-5.98789879).
instead, it gave me a number that is close to the folowing number ofthe same column (-117.3519983)
I disagree
EDIT: oops, too late ...
Message 11 of 13
(415 Views)
The file read in the loop?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 12 of 13
(411 Views)
Not ideal but, we don't have the full spec.  Note: the file path is empty in the OPs version and maintained in my mod.  So, you get a lot of prompts for files.  Cut some slack to the newbie
Message 13 of 13
(406 Views)
