.txt file
how can i create the 3x3 matric  from a .txt file?
How the .txt file should be written?
Message 1 of 9
(5,029 Views)
Use the Read/write spreadsheet file and it'll use a tab separated text file.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 9
(5,027 Views)
The matrix is 2D? That sounds like you are looking for a spreadsheet file in case you really require a human readable file.
There are VIs available which can directly read and write spreadsheet files.
Norbert
Norbert
Expert: Geometry
Message 3 of 9
(5,026 Views)
I should make a report with a .txt file.
The .txt file must be able to create a table with 3 rows and 3 columns.
Message 4 of 9
(5,011 Views)
maybe you need  these vi's
Read/Write a table to/from a file
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 5 of 9
(4,997 Views)
I need to read and building the file below.
Message 6 of 9
(4,991 Views)
That is a normal .ini which you can use the Read Key-function for.
/Y
Qestit Systems
Message 7 of 9
(4,985 Views)
yes it is .ini file
but my problem is in the second section where i can not create the table
Message 8 of 9
(4,980 Views)
Crosspost I guess.  Really a new question was asked.
Message 9 of 9
(4,921 Views)
