type def and string
I created a type def out of a cluster.  One of the elements is a string control.  I hard coded in some string values ..ie Upper Limit...Nominal and Lower Limit.  I "applied changes" and "saved" the .ctrl file.  When I go to my vi and place the type def ctr on my front panel the string is empty.  if I re open the ctrl file the string values are still there.  They don't appear on my vi.  Can you NOT hard code in string values in a type def??  Is the string control just a place holder??
  I tried "Make current values default" and that didn't work.
Thanks..
(5,298 Views)
Have you tried making it a "Strict Type Def"?
(5,271 Views)
It worked for me.  I dropped down a Cluster, put in a Numeric and a String, set values for both, selected "Make Current Default", selected Make TypeDef, saw that the Default Values were in the TypeDef, saved the TypeDef.  Now when I add the Cluster to my block diagram using the TypeDef Control name, it comes with the Default Values for all the components.
Bob Schor
(5,266 Views)
P.S. -- I did not make this a Strict TypeDef, just an "ordinary" TypeDef.  Seems to me I've been doing this ever since LabVIEW 7.0 ...
BS
(5,263 Views)
So from your replies I'm not doing anything wrong.. Guess I'll have to troubleshoot it.  The only thing different from what you did to what I did is my cluster/type def already exsisted.  I opened it up "Open type def" place the string in the open type def...apply changes then closed it.  When I place the cluster/type def on my front panel the string is there but empty!!  When I go back to the type def its populated!!
(5,230 Views)
Thinking there was something wrong w my exsisting cluster/type def I created a new one...same thing!!  The string values exsist when I open the type def but when I place them on a new vi they're blank..  Am I missing a setting in Labview 2014??
(5,224 Views)
Did you remember to select: "Make Current Value Default" under the Advanced right-click option?
(5,196 Views)
