typecast 1D array as 2D?
I have a set of VIs that accepts a 2D array as input.  In some special cases, that input array will be 1D instead of 2D.  Is there any way to typecast that 1D array as a 2D array, so that I don't have to write new VIs (or add case structures to the current VIs) for this special case?
Allan
(3,177 Views)
Accepted by topic author bracker
(3,172 Views)
You might also find the Reshape Array function to be helpful.
Lynn
(3,138 Views)
