typedef struct and a linking a dll
I have a .dll that I'm trying to use in Labview with the "Call Library Function Node".
There is a function in this dll that uses a 'typedef struct' for it's parameter:
   int BACDOCrequest(bdrbag *prqst)
When I go to "Configure->Parameters", what do I use for type and format? I figured I would use "Adapt to Type" but since 'brdbag' is a struct, I don't know how to configure the rest.
The dll author provided an example in C++.
Here is the typedef:
 typedef struct {
        dword    passkey;
        dword    request;
        dword    deviceid;
        dword    objectid;
        dword    propid;
        dword    arrindex;
        dword    datatype;
        dword    value;
        dword    errorclass;
        dword    errorcode;
        dword    priority;
        union {
        char    sval[256];
        byte    bval[256];
        BACnetDate dval;
        BACnetTime tval;
        directaddr da;
        datetime dtval;
        HWND    listbox;
        bufptr    buf;
        Range    rg;
              }    aux;
        } bdrbag;
 Later on, the function is called as follows:
     bdrbag vb;
     vb.deviceid=x;
     vb.passkey=password;
     vb.request=0;
     h=BACDOCrequest(&vb);
 Thanks for any help you can provide!
Don
(4,655 Views)
Don223 wrote:
 typedef struct {
        dword    passkey;
        dword    request;
        dword    deviceid;
        dword    objectid;
        dword    propid;
        dword    arrindex;
        dword    datatype;
        dword    value;
        dword    errorclass;
        dword    errorcode;
        dword    priority;
        union {
        char    sval[256];
        byte    bval[256];
        BACnetDate dval;
        BACnetTime tval;
        directaddr da;
        datetime dtval;
        HWND    listbox;
        bufptr    buf;
        Range    rg;
              }    aux;
        } bdrbag;
You will want to create a cluster that has the same data and wire that up to the dll call. I'm not quite sure how LabVIEW handles unions though
Message Edited by for(imstuck) on 06-16-2010 02:26 PM
Message Edited by for(imstuck) on 06-16-2010 02:27 PM
(4,653 Views)
Here is a post by tbob that is similar. It may answer your question.
(4,645 Views)
Greg what was the result of this?  Did it work?
Smiley LOLSmiley Tongue:womanlol:
(4,322 Views)
