typedef
HI
i would like to know how to add a new control to an existing typedef
(4,803 Views)
Hi
Open the .ctl file,modify and save.
I guess you're modifying a cluster?
(4,787 Views)
yes i want to modifiy a cluster , can you give some instructions please
(4,775 Views)
Step 1: Go through the LabVIEW tutorials.
Step 2: There is no Step 2... Step 1 will give you everything you need -- and more besides.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,770 Views)
Sorry i don't understand
(4,746 Views)
Probably you should start with LabVIEW tutorials and documentation. Or use Google
https://www.youtube.com/watch?v=k5YdyW7OoYw
(4,738 Views)
Oli already told you what you need to do.
If you need further instructions than that, then Mike told you what to do.  Take the tutorials.
(4,737 Views)
