uS event timing with DaqMX help
Greetings.  My Labview experience has been largely cFP and cRIO so my DaqMX experience is limited.  I have a program for my PCIe-6353 that will operate like this:
DO1 high
wait a period as low as 700 uS
DO2 and DO 3 high
wait 700 uS
DO3 low DO4 high
Take analog voltage data at 40 kHz
DO2 low
DO1 low
This is all quite simple but I am not sure what architecture to use for the timing.  Any ideas or examples would be helpful and greatly appreciated.  I have been playing with using multiple timed sequences with different offsets but not sure if this is the best way.  I'm spoiled with the FPGA pallette where I can just drop a uS delay and move on.
Thank you for any input you may have.
Dave B
(2,826 Views)
Bump
(2,797 Views)
What OS is this PCIe board going to be running under? What hardware?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,789 Views)
Hi Dave,
      I think that you would have better luck on the Multifunction DAQ forum.  But to address your issue, there are a couple ways to do that.  First, you could do a Digital Output using a 10kHz clock on your 4 lines.  For this, you could use an example like "Write Dig Chan-Int Clk-Dig Start.vi" found in the NI Example Finder under Hardware Input/Output»DAQmx»Digital Generation.  That example would need to be modified to include the waveform that you've built (either from a waveform constant, or from the Digial Waveform Editor).
Is this generally what your timing diagram would look like?:
Your other option would be to use 4 counters.  Hopefully that gets you started- let me know what you're interested in pursuing.  But again, I would recommend migrating this post to the DAQ forum.  Have a good one!
(2,779 Views)
