03-29-2012 02:50 PM
Hello All,
Not exactly a Labview question but I know there are a lot of smart people here.
03-29-2012 03:07 PM
I was looking at k9nt. There does not seem to be a configuration item, I suspect there is a reg edit that might work. The question should be asked, how would k9nt determine that the UDP packets are coming in your new port location. If you can not answer that, then there is a good chance that k9nt can not do it either. You will need to have another ntp program that you can configure the ntp port location.
