ultrasonic fogger humidifinder vaporizer fogger
Hi. I want to make an ultrasonic fog generator.I have an special ultrasonic piezzo(whitch give out 1,6-2.4 mhz), so I have to make an cirtuit which give ultrasonic signal. I sure know it is 1.6 mhz or 2,4 Mhz its need for the ultra sound crsh water and made real cool (37 degree celsius) fog.
If you have Idea please write me........
so the quetion again ...: how can i made an oscillator circuit which give out 1.6-2.4 Mhz signal (like RLC oscillator).
Thanks....
(4,881 Views)
For hardware design, you need to post to a different board. I'm not sure any of the NI boards are really applicable to what you are looking for.
(4,872 Views)
Hai,
Check out the link: www.discovercircuits.com which has numerous circuits and design ideas with it.
with best regards,
JK
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(4,867 Views)
in addition to JK answer:
Of course you can use a NI signalgenerator card (plus poweramp if needed)
and control it LabVIEW 😉
SCNR
Greetings from Germany
Henrik
LV since v3.1
(4,839 Views)
I wont to recommand on Shira Inc
the company produce ultra sonic 5 micron fogger.
for more info:
yours
dani
(4,781 Views)
