ultrasound transducer & signal measurement
how to start to make a program w/Labview6i.I'll use three different frequencies in sequence and I have to analyze them and to measure amplitudes and times between signals.I'll have function generator and digitizer-all from NI.I developed front panel and now I need to make a block diagram where I have problems to start.Thank you.
(2,841 Views)
If you are using a "function generator and digitizer-all from NI", then I recommend you post this question in a more appropriate category, like perhaps "High-Speed Digitizers" or "Signal Sources", as those categories would pertain more aptly to your question.
Have a pleasant day,
Darren Nattinger
(2,841 Views)
