unable to access shared variable programmatically
hello i have attached a project file where i have created 2 shared variables when i try to access them programatically im getting this error " Error -1967362038 occurred at Read Variable in Untitled 1.vi IAK_SHARED: (Hex 0x8ABC700A) Not found. " can anyone tell me where im going wrong ??
(3,847 Views)
im having trouble in attaching the project file but still if anyone can try it since its a very common problem i guess
(3,844 Views)
im attaching an image of the project created and the vi associated in it i hope this will clear the picture
(3,834 Views)
Accepted by topic author gargrahul
whoof..
found the solution
didnt deployed the library file containing shared variable
so after deploying the library file i was able to access shared  variable programmatically
(3,800 Views)
