unable to create new NI-DAQmx task or global virtual channel in MAX
Hi all!
I am using SCXI device i have installed NI-DAQ 8.0 and when i tried to create a new NI-DAQmx task or NI-DAQmx Global Virtual Channel in Data Neigbourhoodin Max.
the system is processing continuously, but i am unable to create new.Smiley Sad
with regards,
McFerra
(2,713 Views)
I would suggest to uninstall the driver and install NI-DAQmx 8.9.
I think its not a problem of the 8.0 driver, but maybe a corrupt installation or something like that.
If you allready have som channels or scalings configured think about exporting your configuration to a file and then import it again after the re-installation.
(2,652 Views)
