unable to find framedyn.dll
When trying to compile an FPGA on cRIO, a window with the following message popped up: unable to find framedyn.dll.  How can I resolve this and compile the VI?
(3,668 Views)
NI Support solved this problem.  There is a MS KB for this one.  I will remove it from the discussion board.
(3,637 Views)
Here's a better idea:
  • This thread needs to remain so others will also find the solution in the future.
  • You should post a real link to the KB article that solved the problem.
(3,631 Views)
altenback is right, of course.
The link to the MS KB that solves this problem is:
http://support.microsoft.com/kb/319114
(3,628 Views)
