unable to get mulitple digital display on chart
I am running labview 2011 with a chart on windows xp. I turned on the digital display and want to plot more than 1 item at the same time with the digital value. I can increase the number of legends but the number of digital display remains 1.
I thought just by changing the plot numbers, the number of digital display will change. Am I wrong or is there another method to set the number of digital display.
Note this is just a static display.
(2,266 Views)
Accepted by topic author Joseph_Loo
Your chart is empty and you haven't defined what kind of data is going into the chart.
You need to actuallty wire up some data to the chart.  Then it will recognize that you have more than one plot of data and show you all the digital displays.
(2,260 Views)
Thanks. It been too long and brain dead is order of business.
(2,246 Views)
