unable to include a VIT. get error 1003
hi,
i am trying to make an executable for a FLIR camera.
FLIR instruct to add a VIT to the "always included" in order to make the executable work.
when running the executable i get error 1003 "invoke node in.....VI path: ,b.NULL</b>"
this happend at the last stage when the VI is trying to run. see attached VI with error place in it.
i know using VITs is not needed any more but i don't want to dive into FLIRs code.
thanks
Amos
(3,555 Views)
That error code means that the VI is not runable.  And since it is a TEMPLATE, that does not suprise me.  Why not make a VI out of the template and include that?
(3,536 Views)
i don't exactly undersatnd what they did with this VIT ( for example i don't understand the code i posted)
if i make it a normal VI , how do i refer to it from this VI?
amos
(3,531 Views)
To run the nomal VI, you just need to change the VI name that is going into the Build Path just before the Open VI Reference.
(3,529 Views)
