unable to install ni application web server
I want to install the ni application web server on a cRIO-9075.
When I go to add/remove software in MAX, I can select the NI-RIO 4.1.
In the detailed packages I can't select NI-Application web Server 11.5.0(gray).
When I want to select this package I get the message "You cannot select NI Application Web Server 11.5.0 because only an older version (2.0) is installed on your host."
Probably when I install the latest version of the application web server I can deploy it.
Where can I get this latest version?
(2,555 Views)
Hello sambuls,
It seems to me like you have 2 different versions of RIO installed on your PC and your cRIO.
Can you provide us with a MAX Report of your Windows system and of your RT system (the cRIO)?
This will allow us to check what software is missing and/or needs to be installed to make everything function correctly.
Thanks in advance!
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,539 Views)
