my programe reads in off an lvdt transducer through a labjack my programe works up until the LJ stream graph process reads to "scaled data v's seconds" graph.where it graphs a sin wave (amplitude vs time)
for some reason the "freq. amp." analyser won't read the frequency correctly. when i run the programme it outputs a frequency of zero.
note: the amplitude is reading correctly
