unable to start image navigator
Hi
I'm getting started in using DSC. When trying to launch Image Navigator I recieve this pop up: "unable to start image navigator".
Can you help?
Thank you
Tareq
(2,796 Views)
Hi Tareq,
Which version of LabVIEW DSC are you using? On the Front Panel in LabVIEW, can you go to All Controls>>DSC Module>>Pipes Pumps and Valves? It sounds like perhaps the install was not completed properly, in which case you might see missing components in other parts of the application (such as a missing palette).
Jeff M.
Applications Engineering
(2,778 Views)
