unable to use sealevel 3612 card for rs422 communication with labview
Are there drivers to use so as to enable communication on rs 422 using SeaMAC?
I have used Dll which performs the port opening function but i m unable to write onto the port..
(2,716 Views)
There is no in-built driver for your device with LabVIEW. Try contacting the manufacturer for the same.
(2,694 Views)
You will need to install the SeaLevel Systems driver appropriate for your card on the system.
After that, the ports on the card will appear as a normal serial port under windows. No special LabVIEW code is required to access them.
Greg Sussman
Sr Business Manager A/D/G BU
(2,681 Views)
