unavailable distribution in creating installer
Hi
I am now working in version 8.6.1 and when I want to create a installer, there is always a message about some products or their depencencies are in distributions that are unavailable. So what should I do? just insert the CD into the driver and run that again?
(2,736 Views)
Accepted by topic author ycui24
Hey ycuil24,
The message you are receiving is likely due to the fact that you are trying to include additional installers with your application. When you build an installer with additional installers included you may be prompted to locate the original distribution of the installer. To resolve this warning message, you should be able to insert your LabVIEW DVD, which will allow your application to successfully build the installer.
Check out this article on a very similar warning massage: How Do I Stop the Missing Distribution Notification Each Time I Build An Installer
Hope this helps.
-Ben
Hope this helps.
-Ben
WaterlooLabs
(2,710 Views)
