unbuild an array
I would like to know how to unbuild an array, a reverse process of "build array" ?
If it's not possible, how to create a VI with a selectable input/output number.
As "build array", in which you can choose number of input/output by sliding "build array" icone.
Message 1 of 12
(6,451 Views)
"Index array" and "Array subset" functions.
I recommend you to do some tutorials in LabVIEW, this is a far too basic question.
edit:  you can also use a FOR loop with autoindexing to get elements from an array. All depends on your actual task during coding...
Here you can find some learning material:
https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
("Looking for free training" section)
Message 2 of 12
(6,442 Views)
Spend 1 minute to look in the Array palette.  Look at the context help for each of the functions.  You will find more than you were looking for.  But this is a very basic thing that you could have figured out just by digging into the palettes.
Message 3 of 12
(6,421 Views)
Please, before treating people as newbies, try to understand the question..
That what I want to do; Thanks
Message 4 of 12
(6,395 Views)
And Index Array is not doing that for you?
Message 5 of 12
(6,389 Views)
We did understand the question.  Use Index Array and take some tutorials.
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
Message 6 of 12
(6,387 Views)
Good, I forget that index array give output witout any value on index inputs.
So, what about the second part of my question?
..how to create a VI/function with a selectable input/output number.
(that what is really interest me to know?)
Message 7 of 12
(6,344 Views)
Index Array does't do that?  I thought I clearly showed that is how it works.
Message 8 of 12
(6,337 Views)
If you are asking how to create a subVI that has a variable number of array inputs, you can't because the connector pane can't be modified in run-time (unless maybe with VI scripting?).  You just make your input a 2-D array and index that inside the subVI.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 9 of 12
(6,319 Views)
A 2D array needs to be rectangular.  If the 1D input arrays can have different lengths, an array of cluster of array might be better.
Lynn
Message 10 of 12
(6,308 Views)
