unbundle by name stops at 8 names?
@labview12110 wrote:
I did not know that! thanks!
on a side note is this the correct approach? I have data coming in from my daq as a 1d array of waveform dbl and want to break it up and display some values on one graph and others on a different one. unbundle by name, follwed by a merge signals to the chart seems redundant but sort of works. is there a better way?
Index array and build array would be better.  and if you have any Dynamic Data types flying around be wary- those will hide errors in programming until you run the vi.
Message 11 of 11
(368 Views)
