unbundle registered events
Bonjour,
Je suis stagiaire en ce moment et je suis entrain de tester un detecteur de PIC "PKD01" alors pour cela j'ai réaliser un programme sur labview tout en utilisant un DAQmx ni usb 6009.
alors j'ai un problemme dans mon programme parce que je suis tout nouveau sur labview...
je voudrais lire les pic, les mettre dans un tableau puis les enregistrer dans un fichier excel. et à chaque fois que je lit un pic je dois renitialiser si non il me dectera pas le pic suivant s'il est plus petit.
Pour renisialiser je dois ecrire un 1sur les 2 pattes de commande du PKD01 .
Pour detecter je dois envoyer un 0.
vous trouverz si joint mon programme sur labview.
Merci d'avance
Message 11 of 29
(2,140 Views)
Shane,
now i think i understand what you are up to:
But i am not sure if this is possible with simple user events. If you are able to solve this, i hope we will see another interesting nugget 🙂
Norbert
Message Edited by Norbert B on 06-02-2008 10:10 AM
Norbert
Expert: Geometry
Message 12 of 29
(2,132 Views)
Intaris, could you give a little diagram of what you are trying to do?
User events are very powerfull and never let me down.
A little scheme or handdrawing should be OK
Ton
My LabVIEW Ideas
Message 13 of 29
(2,126 Views)
Norbert,
I'm not aqll to familiar with DAQ-mx, but if the pic you show is allowing an event to be fired based on the choice of the drop-down list then yes, this is exactly what I was thinking.
Of course, we could go about it another way.  Here's a pretty simple example (using a counter as a "device driver").
The only possibility for misuse is the availability of a refnum for the just-fired event when catching a user event.  This actually shows that it IS possible to get at the event refnum from a "register for events" wire, it's just not public.  I have added a switch to trhe front panel of the following VI showing this mis-use.  Why do we have the event refnum exposed here?
Shane.
PS Forgot to add: LV 8.2.1
Message Edited by Intaris on 06-02-2008 10:32 AM
Message 14 of 29
(2,126 Views)
You can group them like the attached if you only want one wire.
Randall Pursley
Message 15 of 29
(2,124 Views)
TonP,
I just saw your response.  Have a look at the code for an example.  It's basically using pre-defined Events to define an interface between two parts of code.  The device driver generates the events (or registers them) whereas the application software uses them.  It's kind of a user-event based producer consumer architecture.  No queues.
Shane.
Message 16 of 29
(2,126 Views)
rpursley8,
just saw your response too. Am I so slow in answering that everyone's answering before I post.... Smiley Surprised
If you look in the code I posted, this is exactly what I did.
Shane.
Message 17 of 29
(2,124 Views)
I think I know of two existing tools which do what you want: LVx and the Active VI toolkit (which uses XNodes). I think that LVx actually does exactly what you want, but I didn't look deeply into either of them.
___________________
Try to take over the world!
Message 18 of 29
(2,113 Views)
Intaris,
your code looks OK, I would move the register for the talk-back event into the Application Layer:
Ton
Message Edited by TonP on 06-02-2008 06:20 PM
Message Edited by TonP on 06-02-2008 06:24 PM
My LabVIEW Ideas
Message 19 of 29
(2,103 Views)
TonP,
I did that on purpose to ensure the events are "Read-only" so to speak.
Shane.
Message 20 of 29
(2,096 Views)
