unbundle shows disabled element in the cluster
Hello Everybody
See the enclosed gif to see my problem.
The unbundle by name shows that the element of the cluster is disabled, whereas the "step by ste" unbundle by name shows all cluster element ready to use.
I have found the simmilar problem here:
simmlilar problem
but there was no answer for that.
Do you have any clues?
thanks in advance.
Pawel
(2,710 Views)
I just want to add some more info to the subject, since I have found interesting stuff yesterday.
I enclose the control I am talking about.
The control contains cluster and inside the cluster there is another clusters. As I have shown in the previous post, some of the elements in the cluster are disabled. What is really funny in all of it, is that by adding or remowing some elements of the basic cluster, the disability is shifted to other cluster elements. Yes, just like that. Do it by your own, try to to add a boolean in the big - front pannel - cluster. Then do not forget to rearange the order of elements to have your control somewhere in the beggining. You will see that now other elements are disabled. What the heck it that??????
What
is interesting that, the disable view of the elements occur also in other sub-cluster. When you add the boolean the disability is also shifter. This shift equals the amount of controls you put to the cluster. I count that if I expand all clusters and treat their elements as one cluster, than the distance between disabled positions equals 9 !!!. This distance is unchanged.
I enclose two vi with the control I am talking about and with corresponding pictures.
What to do with it???
kind regards
Pawel
(2,710 Views)
The technique Jeanne-Pierre outlined in your "similar problem" link works here as well.
How did you develop this cluster?
I suggest you report this to NI as a bug.
Ben
(2,710 Views)
