unbundle
Hi!
I have a rather simple problem!
When I use the "unbundle" function I would like
to change the number of outputs from it, exactly
the same number as the input number in my read function (See my attached file). I always get
nine outputs!!
(3,034 Views)
Right click the array to cluster function and change the cluster size to the number of input used,,
9 is only a default number so change it to the number of inputs it is connected to ,,
(3,034 Views)
thanks!
(3,034 Views)
