uncheck radio button
why is that delay...anyhow the code doesn't work
Regards
RobinHood
Message 11 of 21
(1,997 Views)
thanks Dave
Regards
RobinHood
Message 12 of 21
(1,992 Views)
Delay is needed for avoiding 100% CPU load in While loop
The code is work. What is your expectation?
Andrey.
Message 13 of 21
(1,992 Views)
Andrey,
besides the original discussion: i would expect code without any sequence structure 🙂
Norbert
Norbert
Expert: Geometry
Message 14 of 21
(1,987 Views)
Norbert B wrote:
Andrey,
Norbert,
Impossible is nothing, sure:
More wishes? 🙂
Andrey.
Message 15 of 21
(1,981 Views)
How did you get that radio buttons in the first frame. and i've wriiten like this.is it correct?
Regards
RobinHood
Message 16 of 21
(1,972 Views)
No need of the sequence structur. will work the same way...
Message 17 of 21
(1,959 Views)
You can createe Property Node for whole Radio Button Group of for each Button individually. It depends from the Mouse Click Position:
See differences:
vs
Also you can create property node from Block Diagram (for whole group):
Andrey.
Message 18 of 21
(1,957 Views)
Well, great improvement, Andrey 🙂
But there are always places for improvement as you know 😉
Regarding RobinHood: You are a fan of the Abort Button, aren't you? Please note that it is sign of bad programming style if you are depending on it!
Please implement something like Andrey has shown or improve it further by using a Statemachine, a UI Event Handler or another standard architecture like shown in the Template Browser in the folder "Design Pattern".
Norbert
PS: To quote the most famous signature of this forum: "Never use the Abort Button to stop a VI. It's like stopping your Car with a tree; it works, but it may have consequences!"
Message Edited by Norbert B on 02-11-2010 04:44 AM
Norbert
Expert: Geometry
Message 19 of 21
(1,954 Views)
Only if error outputs of the property nodes will be connected to the border of the while loop. Otherwise data flow will be changed (well, in the given example user will probably never seen the changes, but formally just removing sequence structure will caused race conditions immediately)
Andrey.
Message 20 of 21
(1,945 Views)
