unicode on run-time menu
Does anyone know how to use unicode on the run-time menu
(3,625 Views)
By run time menu you mean LabVIEW block diagram?
Miguel Fonseca
http://www.ni.com/support
(3,598 Views)
No... i mean the menu bar.  When i use unicode, some funnny characters would display
(3,591 Views)
Hi, Unicode is not officially supported by the LabVIEW environment. But you can use basic support of Unicode available as described in this document.
Miguel Fonseca
National Instruments - Applications Engineering
(3,574 Views)
