uninstall 6.0.2
Dear Group,
I know that this has been asked before but is there a solution to the the
fact the the lv 602 upgrade kills the lv6i uninstaller?
I have tried to uninstall lv60 upgraded to 602 and I cant.
Is it true that I will now need 602 for all my vi's to work and I will not
be able to use them in LV6i? They have all been 'upgraded' to 602 spec.
James
(2,696 Views)
Labview only upgrade your vi to the newest version if it is been saved. In other words, if you opened a 6.02 version vi but did not save it, then you should be able to open it in 6i. (if you did a mass compile with 6.02, then use the following method) If you already save it, well, you can save the vi again to v5, open it in 6i and save.
Joe
(2,696 Views)
LabVIEW 6.0 will have no problem opening LabVIEW 6.0.1 or 6.0.2 VIs.
(2,696 Views)
