uninstall Labview 7.1
How could I uninstall LabView 7.1 and leave 6.02 on a windows computer?
Andres
(3,657 Views)
Hey Andres - go to control panel - add remove programs and select National Instruments S/w and say Change - there select LabVIEW 7.1 and click uninstall - That should solve your problem
Thanks VNIU
(3,657 Views)
Hi NVU,
Thank you for your answer. I tried that. First it offers me to uninstall the application builder and no more. When I tried that again then i received a message: �NI shared components were detected that are not associated with any products. Would you like to remove these shared component?� and no option to uninstall the LabView 7.1. I am using Windows NT, may be that is a problem.
Andres
(3,657 Views)
Hello andres,
Does LabVIEW 7.1 not show up when you click modify under National Instruments software. If it is not, have you been able to confirm that it is still installed on your machine?
What components do show up under National Instruments software?
Matt F
(3,657 Views)
Hello andres,
Matt F
(3,657 Views)
