uninstall related
I want to uninstall NI product on my computer, but the NI unistall option does not appear on control panel. Also, I can't find 'NIUninstaller' folder or 'uninst.exe' under National Instruments folder ( also I checked shared folder, it is the same). Is that possible for anyone send me a copy of the 'NIUninstaller' folder?
or
My I use other app like MSI blast to uninstall NI products?
Message 1 of 16
(6,355 Views)
I Leon89,
Did you follow this procedure?
http://digital.ni.com/public.nsf/allkb/F4B8D92A304E4A7B862577460072002F
Regards
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 2 of 16
(6,351 Views)
Hi Leon,
usually you will find an entry "National Instruments" in the programs list:
Calling this item will start an uninstaller!
Message 3 of 16
(6,344 Views)
I just did this last week.  On my Windows 7 x64 machine, there was a "National Instruments Software" entry under Programs and Features in Control Panel. If I double-click it, I get the following screen:
I chose "Remove All", then took a four-hour coffee break ... (I had 1300 or so things to be removed ...).  The re-install (not as much) was not much slower ...
Bob Schor
P.S. -- I notice you failed to mention (a) which version(s) of LabVIEW you were trying to remove and (b) from what sort of machine and OS.  If you're talking about taking LabVIEW 3 out of a Mac, I certainly can't make any useful suggestions ...
Message 4 of 16
(6,306 Views)
Thanks all, maybe I havent clearly discribe my situation.
OS: windows 10; Labview: v 14.0
I do tried to follow the recommened way (http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D) to uninstall NI programs, but it doesnt work for me.
The reasons for that are:
1. As the image shows, I cant find any NI program in uninstall or change a program.
2. In NI folder, I found shared folder but in that folder the 'NIUninstaller' does not exist, which means I dont have 'uninst.exe' for uninstalling the programs.
So, what can I do next ?
Can anyone copy the 'NIUninstaller' folder for me?
or
Can I using other program like MSI blast to uninstall the NI programs?
Message 5 of 16
(6,283 Views)
Are these mostly empty folders in the NI hierarchy? Maybe things already got uninstalled and these are just the leftover bits?
Message 6 of 16
(6,270 Views)
No, all of the program are there. Only the NIuninstaller folder disappear. Also, I can find NI products uninstall info. in register but I cant do more.
Message 7 of 16
(6,254 Views)
did ou tried the procedure in the link I sent you above?
Message 8 of 16
(6,244 Views)
Thx Sabri.
I tried. There is not folder named 'NIuninstaller' under shared folder, and obviously I cant find uninst.exe at all.
Message 9 of 16
(6,219 Views)
What happens if you try to install it?
Message 10 of 16
(6,193 Views)
