unknown CLAD question
How does changing a DAQ board from a 0-10 volt range to a -10 to 10 volt range, affect the minimum voltage change that can be detected?
A.The minimum voltage change that can be detected will be split in half.
B. There will be no effect on the minimum voltage change that can be detected.
C. The minimum voltage change that can be detected will be doubled.
D. The minimum voltage change that can be detected will depend inversely with the resolution of the board.
(3,147 Views)
You should be able to figure that out from the formula someone posted in your other thread where you asked a similar question.
Lynn
(3,135 Views)
I think answer is C.. Is it correct?
(3,120 Views)
C:
Assuming they are talking about an Analog Input task (For an analog output the answer lies in the external test equipment).
Every AI channel goes first through a gain/filter stage the signal out of the gain stage will vary from the ADC's negitive rail to its positive rail.  Therefore to change from a 10 swing to a 20 volt swing the gain must be halved and each bit step size (referanced to input) is doubled
(3,090 Views)
